plane acoustic wave in solid
I want to simulate a simple plane acoustic wave traveling through a solid. Therefor I implement a pressure source on a surface boundary as Radiation Condition. I suppose that the wave uses the speed of sound of the subdomain. But in the result the pressure is everywhere from the beginning on. No traveling wave can be seen. I considered the solver time steps in the range of the speed of sound.The wave direction vector should also be right.
Does anybody have an idea where my fault is?
Thanks a lot!
C.Mannal
2 Replies Last Post Oct 4, 2013, 9:55 a.m. EDT
Posted: 2 decades ago Mar 25, 2010, 5:36 a.m. EDT
acoustic wave dont exist in solid they are called elastic waves and are of different kinds [ p wave s wave.. and so forth the problem is MUCH more complicated than in gas or liquid.
if yu know in advance, as it happen sometime, that only one kind of wave exist [ p waves most commonly] you can write a simplified pde that handle only this kind of wave. I dngt have acoustic module so I cannot say whether or not this module can handle that but you need to know what you are doing if you go that route.
To the best of my knowledge [ but i can be wrong on that so it is worth double checking], comsol does not handle elastic wave at the moment.
th
jf
acoustic wave dont exist in solid they are called elastic waves and are of different kinds [ p wave s wave.. and so forth the problem is MUCH more complicated than in gas or liquid. if yu know in advance, as it happen sometime, that only one kind of wave exist [ p waves most commonly] you can write a simplified pde that handle only this kind of wave. I dngt have acoustic module so I cannot say whether or not this module can handle that but you need to know what you are doing if you go that route. To the best of my knowledge [ but i can be wrong on that so it is worth double checking], comsol does not handle elastic wave at the moment. th jf
Walter Frei COMSOL Employee
Posted: 1 decade ago Oct 4, 2013, 9:55 a.m. EDT
COMSOL does have the capability to model elastic waves. There are several good examples online:
www.comsol.com/model/saw-gas-sensor-2129
www.comsol.com/model/acoustic-transmission-loss-through-periodic-elastic-structures-1974
www.comsol.com/model/acoustic-structure-interaction-417
www.comsol.com/model/wave-propagation-in-rock-under-blast-loads-12811
COMSOL does have the capability to model elastic waves. There are several good examples online: http://www.comsol.com/model/saw-gas-sensor-2129 http://www.comsol.com/model/acoustic-transmission-loss-through-periodic-elastic-structures-1974 http://www.comsol.com/model/acoustic-structure-interaction-417 http://www.comsol.com/model/wave-propagation-in-rock-under-blast-loads-12811
