extract particle data on cut line
I've built a 2D axis symmetric model in which particles go trough an electrical field. Now I'd like to extract the particle positions and velocities on a cut line. I've found the Poincaré map in the plot nodes, but I am not interessted in nice pictures, but in the data.
Any suggestions how I do that?
Cheers,
Gero Storeck
2 Replies Last Post Feb 14, 2014, 4:38 a.m. EST
Posted: 1 decade ago Feb 14, 2014, 2:02 a.m. EST
You can export the data in the plot to a file as follows:
1. Create a Poincaré map plot.
2. Select the plot in the Model Builder and right-click on it.
3. Choose "Add Plot Data to Export" on the context menu. This results in a Plot node being created under Results > Export.
4. Browse to a filename in the Plot export node.
5. Click on Export in the toolbar.
You can export the data in the plot to a file as follows: 1. Create a Poincaré map plot. 2. Select the plot in the Model Builder and right-click on it. 3. Choose "Add Plot Data to Export" on the context menu. This results in a Plot node being created under Results > Export. 4. Browse to a filename in the Plot export node. 5. Click on Export in the toolbar.
Posted: 1 decade ago Feb 14, 2014, 4:38 a.m. EST
Thanks for the hint. But I think I need further input.
I am modeling 3D particle propagation in a axissymmetric 2D eletrical field. There is a unsolved thread about that topic already (www.comsol.com/community/forums/general/thread/23345/). I hope the 'Include out-of-plane degrees of freedom' takes care of this.
But the created dataset 'Particle 1' only includes two position coordinates 'comp1.qr, comp1.qz'. That means I cannot use a 2D cut plane because the qphi component is missing. Funny thing is that I can extract this data (qr, qphi, qz) via 'export' or the livelink to matlab.
The dimensions for plotting don't fit unfortunatly. My goal is to extract the positions, velocities and the hit time at different planes perpendicular to the symmetry axis.
Cheers,
Gero Storeck
Thanks for the hint. But I think I need further input. I am modeling 3D particle propagation in a axissymmetric 2D eletrical field. There is a unsolved thread about that topic already (http://www.comsol.com/community/forums/general/thread/23345/). I hope the 'Include out-of-plane degrees of freedom' takes care of this. But the created dataset 'Particle 1' only includes two position coordinates 'comp1.qr, comp1.qz'. That means I cannot use a 2D cut plane because the qphi component is missing. Funny thing is that I can extract this data (qr, qphi, qz) via 'export' or the livelink to matlab. The dimensions for plotting don't fit unfortunatly. My goal is to extract the positions, velocities and the hit time at different planes perpendicular to the symmetry axis. Cheers, Gero Storeck
