Unrealistic results in Elasto-Plastic analysis: Thermal Stress Problem
Posted Feb 25, 2014, 12:41 a.m. EST Heat Transfer & Phase Change, Geometry, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers, Structural Mechanics 3 Replies
I am modeling a Thermal stress analysis of 3D wire wherein Temperature field (x,y,z) was imposed by using Interpolation function (imported a .txt file). It is simply an Elastic-Plastic analysis. Because of higher values of imposed temperatures, specimen goes into plastic region. I set the Linear elastic-Perfectly Plastic model (i.e. The plastic region starts when induced stress exceeds the Yield strength of the material).
However, the result are unrealistic i.e. Elastic strain are very low, a zero plastic strain and only thermal strain is very high. I think the total strain is mainly showing up as Thermal strain and contribution of other strains are almost zero.
I have attached the report file. Need help. Any comments or suggestions are appreciated.
3 Replies Last Post Feb 26, 2014, 9:16 a.m. EST
