How to get deposition rate of particles in fpt module? Or should I use an auxiliary Dependent ?variable
Posted Mar 31, 2014, 8:49 a.m. EDT Charged Particle Tracing, Fluid & Heat, Particle Tracing for Fluid Flow Version 4.3b 0 Replies
I have been doing a model using the "fluid flow" and "particle tracing for fluid flow "module. A bell type insulator is placed across the flow channel. I have implemented the boundary condition to stick , so whenever a particle hits the insulator, it get stick with the insulator wall.
Now, If I want to calculate how many particles are stick with the insulator wall by the time I'm interested and the rate of particle deposition from the result section, how I am supposed to do that?
Thank you.
Hello Longxiang Fengzhu
