mphplot: multiple legends
At the mphplot voice of the online documentation:
Only one color range bar and one legend bar is supported in a MATLAB figure. When the option plot on server is active, all active color range bar are displayed.
That's very disappointing. I actually have a surface plot and a countour plot in the same figure and I want to see the scales for both.
I don't really understand the second sentence: When the option plot on server is active, all active color range bar are displayed. But activating the plot on server option does not help (maybe I should explore it a bit more, but I don't see what is it doing).
(I actually also have an arrow plot, but I believe there is no legend in comsol for the arrow plots, right?)
1 Reply Last Post Apr 17, 2014, 7:06 a.m. EDT
Posted: 1 decade ago Apr 17, 2014, 7:06 a.m. EDT
I sort of found a way around this. If you start matlab via the server with the graphics option
comsol server matlab -graphics
then you can use the comsol graphic window and see all the legends and colorbars in the plot.
You can then create an export node but then I don't know how to save it.
model.result.export('img1').run
is not creating the desired file. Any suggestions?
I sort of found a way around this. If you start matlab via the server with the graphics option comsol server matlab -graphics then you can use the comsol graphic window and see all the legends and colorbars in the plot. You can then create an export node but then I don't know how to save it. model.result.export('img1').run is not creating the desired file. Any suggestions?
