How to draw the geometry of the tapered fiber
Hello everyone, I try to draw the tapered fiber, but it is difficult to define the cross-section radius of the tapered fiber as the function of the z axis. maybe in COMSOL, the geometry parameters can not be the function of the axis parameters (namely, x, y, z)? How to draw the tapered fiber in COMSOL, thanks a lot!
1 Reply Last Post May 23, 2014, 8:51 a.m. EDT
Posted: 1 decade ago May 23, 2014, 8:51 a.m. EDT
Hello Guoyong,
I suggest the following:
- Create a function that defines your taper profile (radius function) as a function of the longitudinal axis r(z). Plot it and make sure it defines the profile you are looking for.
- Use revolve feature, to revolve planar objects into 3D.
cheers,
Felipe BM
Hello Guoyong, I suggest the following: - Create a function that defines your taper profile (radius function) as a function of the longitudinal axis r(z). Plot it and make sure it defines the profile you are looking for. - Use revolve feature, to revolve planar objects into 3D. cheers, Felipe BM
