May 28, 2014, 5:34 a.m. EDT
This is analogous to bulk vs. surface concentration. The common paradigm of converting them to each other is that the standard bulk concentration 1.0 mol/L corresponds to the surface conc. 1.184e-6 mol/m², which can be derived from simple geometric considerations.
Wish this helps
Lasse
Wish this helps
Lasse
May 28, 2014, 6:14 a.m. EDT
Hence, if you have DOS of x m^-3 it corresponds to y = x^(2/3) surface DOS.
May 28, 2014, 7:29 p.m. EDT
Thank you so much! I'll think about that, try to see if it works. Thanks again!
8 years ago
Mar 7, 2016, 12:41 a.m. EST
Hello, I am trying to simulate a MOSFET which has a graphene channel. I am using semiconductor module of COMSOL in this case. But I face some problem here,
I need to define graphene by defining the parameters of Graphene-but I still need some parameter which I am facing difficult to fix. such as-
1. Bandgap
2. Effective density of States of Conduction band
3. Effective density of states of Valence Band
4. What kind of doping model should I use in this case?
5. Electron and hole life time in Graphene.
Can you please help me with this parameters? I need to work on it soon. It will be a great help. Thanks !
1. Bandgap
