Jul 4, 2014, 8:04 a.m. EDT
So, what is the problem?
9 years ago
Jun 17, 2016, 7:45 a.m. EDT
I´m a researcher of the Microelectronics Institute of Seville (IMSE), and I would like to make a similar simulation to that of Ali Shah you replied (it´s further down). ¿Could you help me a little bit with the modeling process, please?
I would like to make a simulation of a nano-bar of aluminium on a substrate (modeling a nanoantenna), receiving heat radiation. In principle, this could be a heat point source (located 1m away from the antenna on a normal line coming up from the middle point of the antenna), but we could be also interested in an external source coming from the sun, as modeled in the Heat Transfer module. I have here attached the model I built.
Thank you anyway,
kind regards,
Alfredo
Ali Shah
July 2, 2014 9:51pm CEST
Simulation of Point Heat Source in different Medium.
I want to make a simulating point heat source which will emit heat in different Rectangular Mediums in (Vaccum, air,Fluid and solid), and finally to compare the results.
Need Assistance.
Alishah
Thank you anyway,
kind regards,
Alfredo
Ali Shah
Need Assistance.
Alishah
9 years ago
Jun 20, 2016, 10:51 a.m. EDT
Since one of the dimensions of your geometry is in the same order of magnitude as the wavelength of your irradiation (visible/IR light I assume?) I think you need to do a full optical simulation of your device to get realistic heating. However since your device is small compared to the distance to the light source the light can be modelled by a planar wave I think.
