read temperture from conductor model and use it in equation
Posted Jul 5, 2014, 5:45 p.m. EDT Computational Fluid Dynamics (CFD) Version 4.3 1 Reply
I am working with a 2D model. I have a circle which represents the cross-sectional area of an overhead line conductor. Around that circle, I draw a rectangle and gave fluid properties (air) to it. This rectangle simulates the convection cooling on the conductor as the conductor gains heat from solar radiation and Joule heating. For this model I use the conjucated heat transfer.
However, I would like to read and store the maximum temperature of the conductor (circle) in a variable named Tmax for example. I have defined Joule heating as a heat source on the conductor surface and is equal to (I^2)*R. The resistance of the conductor (R) varies with conductor temperature in a linear manner.
Let's say for example R=2Tmax+5. I want to store Tmax in a variable and use it in the expression of resistance R. Is there a way to store and use Tmax in R expression?
Also, how can I do this, in order to enable the value of resistance to change automatically as temperature of conductor Tmax varies?
1 Reply Last Post Jul 11, 2014, 8:03 a.m. EDT
