Failed to compute elastoplastic strain variables
I am doing elasto-plastic analysis with initial strains. It is a parametric study with variables in geometry of the model. While solving the problem, for some cases in parametric study it is through. However, for some cases there is error as mentioned in subject.
I have tried it with modifying mesh but no results.
I would be grateful if someone could take a look and point out the mistake in my method.
Thanks in advance
Rishi
1 Reply Last Post Jul 11, 2014, 7:28 a.m. EDT
Posted: 1 decade ago Jul 11, 2014, 7:28 a.m. EDT
If you search the forum for "Failed to compute elastoplastic" you will find at least half a dozen threads on this subject.
Knowledgebase entry 1150 also discusses this error message.
www.comsol.com/support/knowledgebase/1150/
Henrik
Hi, If you search the forum for "Failed to compute elastoplastic" you will find at least half a dozen threads on this subject. Knowledgebase entry 1150 also discusses this error message. www.comsol.com/support/knowledgebase/1150/ Regards, Henrik
