parametric surface
Hi All,
I am looking for a way to define a cylinder by using the parametric surface in my modelling. this surface is meant to be used only in post processing part to take a surface average of temperature.
thanks for your help.
ASAL
1 Reply Last Post Aug 4, 2014, 1:33 p.m. EDT
Posted: 10 years ago Aug 4, 2014, 1:33 p.m. EDT
Sure, you can do that. In the classical notations for a cylinder aligned with the z axis in a cylindrical coordinate system, use "theta" as your first parameter and z as the second.
Sure, you can do that. In the classical notations for a cylinder aligned with the z axis in a cylindrical coordinate system, use "theta" as your first parameter and z as the second. Jeff
