Shorting one end of three cables
Posted Sep 16, 2014, 6:34 p.m. EDT 8 Replies
I want to simulate the experiment I do in the lab. I have one ends of 3 cables energized from 3 phase source while the other ends are shorted. I am running 2D simulation, therefore, does anyone have idea how can I short one ends of the cables in 2D?
Akim
You can use the Electric Circuit, see the attached example.
Dima.
Dima Apter
A2Z Consulting Ltd.
www.a2z-consulting.com
Thank you so much! I wonder what are External I Vs. U 1, Eormsxternal I Vs. U 2 and External I Vs. U 2 for? Are they for current waveforms or something else?
Akim
Thank you!
If you open Help window within COMSOL and then click on the feature node you will get the following:
"The External I vs. U feature connects an arbitrary voltage measurement (for example, a circuit terminal or circuit port boundary or a coil domain from another physics interface) as a source between two nodes in the electrical circuit. The resulting circuit current from the first node to the second node is typically coupled back as a prescribed current source in the context of the voltage measurement."
Dima Apter
A2Z Consulting Ltd.
Can you help me also in the following matter? My cables have metallic (aluminum) sheath and they are bonded at both ends and grounded, thus resulting in circulating currents in the sheaths. I wonder how can I model these circulating currents in the sheaths in Electrical circuits interface? Since these currents are induced and voltage between the two ends of sheaths is zero (or negligible) I cannot model them as current source or voltage source, right? Can current controlled current source be used to define sheath circulating currents?
Thanks!
Akim
1. Build the sheaths as separate domains.
2. Define them as additional Single-Turn Coil.
3. Select "Voltage" in the "Coil Excitation" and set it zero.
Check if it will work for you.
Best Regards,
Dima.
Dima Apter
A2Z Consulting Ltd.
Suggested Content
- BLOG Simulating Thermal and Electrical Stresses in Medium Voltage Cables
- FORUM three-dimensional superconducting
- FORUM Inquiry on Modeling Two PDEs with Three Dependent Variables in COMSOL
- BLOG How to Model the Electromagnetic Heating of Underground Cables
- KNOWLEDGE BASE The Usage of Form Union and Form Assembly
