Points on curve
Hello
I am new to comsol and I am trying to figure out how to put a point on a curve?
Thank you
3 Replies Last Post Apr 21, 2010, 4:43 p.m. EDT
Posted: 1 decade ago Apr 21, 2010, 2:17 p.m. EDT
if its the tick marks, it's in the plot window under the palette, select the line and then update marker. Note that in V3.5a only one point of 2 are marked, not all, and that do not know howto change ;)
But I might have missed the true question, if so, pls come bakc
Have fun Comsoling
Hi if its the tick marks, it's in the plot window under the palette, select the line and then update marker. Note that in V3.5a only one point of 2 are marked, not all, and that do not know howto change ;) But I might have missed the true question, if so, pls come bakc Have fun Comsoling Ivar
Posted: 1 decade ago Apr 21, 2010, 3:56 p.m. EDT
Thank you Ivar. I might be misunderstanding your suggestion, but I do not think it addresses my question. I have a 2D model (axi-sym) of half of a spherical shell. The inner wall of the shell is a curve and is described by its center point and the two ends of the arc. I want to add additional points along the curve which I'd like to use to apply boundary conditions to. Is there a way for me to simply add one/multiple points along the arc? (say in draw mode?)
Posted: 1 decade ago Apr 21, 2010, 4:43 p.m. EDT
Indeed, then you want what I call "hard points" on the model boundaries (edges) either for node definition or for as you state boundary point loads (these are not good practice as point wise nodes loads are singularities but in many cases they are ok). I use mostly surface loads, in 2D that means line loads as lines are in fact surfaces with default "thickness" or depth of 1[m]
You can define points in the 3D/2D (as you can make lines and shapes), or you make your curve as segments, or you split your volume with lines. In 2D COMSOL geometry the lines might overlap the shapes, when you go from geoemtry mode to assembled geometry (in matlab the geomanalyse() command), extra points are added at intesections, and geoemtry not definable are dropped (such as extra single lines attached to no surface in 2D).
you can also "split" select shape and extra lines and "coerce to solid" you shapes to regroup them.
If you use "assembly mode" the geomanalyse is not behaving the same way and you must "group" = "cource to solid" the parts you want considered as one entity, before you go to the boundary or edge definition GUI.
I often cut my volumes/areas with lines to enforce symmetry (nodes will line up on the interiour edges before they fill the volumes), or to make metrology boundaries. These are mostly then "interiour" boundaries with "continuity" conditions, the few extra boundaries seldom poses a problem to the complexity of the model.
hope this is better then,
Hi Indeed, then you want what I call "hard points" on the model boundaries (edges) either for node definition or for as you state boundary point loads (these are not good practice as point wise nodes loads are singularities but in many cases they are ok). I use mostly surface loads, in 2D that means line loads as lines are in fact surfaces with default "thickness" or depth of 1[m] You can define points in the 3D/2D (as you can make lines and shapes), or you make your curve as segments, or you split your volume with lines. In 2D COMSOL geometry the lines might overlap the shapes, when you go from geoemtry mode to assembled geometry (in matlab the geomanalyse() command), extra points are added at intesections, and geoemtry not definable are dropped (such as extra single lines attached to no surface in 2D). you can also "split" select shape and extra lines and "coerce to solid" you shapes to regroup them. If you use "assembly mode" the geomanalyse is not behaving the same way and you must "group" = "cource to solid" the parts you want considered as one entity, before you go to the boundary or edge definition GUI. I often cut my volumes/areas with lines to enforce symmetry (nodes will line up on the interiour edges before they fill the volumes), or to make metrology boundaries. These are mostly then "interiour" boundaries with "continuity" conditions, the few extra boundaries seldom poses a problem to the complexity of the model. hope this is better then, Good luck Ivar
