Geometry related parameter sweep
In my COMSOL model ,I have two geometry related parameters. I want to sweep them together. The fisrt parameter has 45 numbers and the second has 60 numbers.But I found that COMSOL would not work for geometry related parameter sweep.
How can I solve this problem.
2 Replies Last Post Oct 20, 2014, 3:34 a.m. EDT
Posted: 10 years ago Oct 20, 2014, 3:03 a.m. EDT
When you say that it does not work - what do you mean?
If you could upload your model, or a simplified version of what you are working with it would be much easier to help.
BR Simon
When you say that it does not work - what do you mean? If you could upload your model, or a simplified version of what you are working with it would be much easier to help. BR Simon
Posted: 10 years ago Oct 20, 2014, 3:34 a.m. EDT
I have swept geometry without any problems. In your case the issue is the large number of parameters. The solution data woud not fit to anywhere. I have used only 12 values in a rather simple geometry, and that file was already a big one.
Lasse
[QUOTE] In my COMSOL model ,I have two geometry related parameters. I want to sweep them together. The fisrt parameter has 45 numbers and the second has 60 numbers.But I found that COMSOL would not work for geometry related parameter sweep. How can I solve this problem. [/QUOTE] I have swept geometry without any problems. In your case the issue is the large number of parameters. The solution data woud not fit to anywhere. I have used only 12 values in a rather simple geometry, and that file was already a big one. Lasse
