how to get the DEP force
Hi everyone
How to get the DEP force in the particle tracing module?
I add the DEP force in the particle tracing module and than study it.
But the errors are as follows:
Failed to evaluate variable Jacobian.
- Variable: freq
- Geometry: 1
- Domain: 5
Failed to evaluate operator Jacobian.
- Operator: env_pgeom_fpt
- Geometry: Particles
I get the electric field data from the RF module
2 Replies Last Post Dec 2, 2014, 5:43 a.m. EST
Hello Zerong Yuan
Posted: 1 decade ago Dec 2, 2014, 4:52 a.m. EST
Did you get your result? Solved the Jacobian operator issue?
Please let me know, as am facing similar problem
Hi, Did you get your result? Solved the Jacobian operator issue? Please let me know, as am facing similar problem
Posted: 1 decade ago Dec 2, 2014, 5:43 a.m. EST
I guess the 'freq' is the built-in variable in COMSOL, so I added the parameter named 'freq' in 'global parameter' to replace the 'f0' which I used to indicate the frequency.
Hi, I guess the 'freq' is the built-in variable in COMSOL, so I added the parameter named 'freq' in 'global parameter' to replace the 'f0' which I used to indicate the frequency.
