Plotting Volumetric Charge Density
I am using COMSOL to plot charge density, electric field, and potential in a nanowire as different forces are applied.
Is there any way to plot volumetric charge density?
1 Reply Last Post Oct 25, 2014, 4:24 a.m. EDT
Posted: 10 years ago Oct 25, 2014, 4:24 a.m. EDT
What do you mean by volumetric charge density ?
is it the charge density in cut planes inside the volume ? If so you have the cut plane plots, or cut plane Data sets, check the COMSOL video on post-processing, or your doc
Hi What do you mean by volumetric charge density ? is it the charge density in cut planes inside the volume ? If so you have the cut plane plots, or cut plane Data sets, check the COMSOL video on post-processing, or your doc -- Good luck Ivar
