Inductive sheet impedance in transient simulation
I am using the transient RF module in Comsol 4.4. I want to assign a sheet impedance, Zs, on a boundary such that Etan=Zs*Js, where Etan is the tangential electric field on the boundary and Js is the surface current density on that boundary. This expression is applicable in the frequency domain. To define a capacitive surface impedance in the time domain, I assigned a surface current density of Js=Cs*d(temw.Ex,t), where Cs is the surface capacitance.
However, I am running into trouble when I try to define an inductive impedance. In this case, we need temw.Ex=Ls*dJs/dt which leads to a surface current density of Js=timeint(0,t,temw.Ex)/L. This expression is not acceptable by Comsol.
My question is: How can I define an inductive sheet impedance on a boundary?
Thank you
1 Reply Last Post Dec 11, 2014, 6:51 p.m. EST
Hello Nikolaos Chiotellis
Posted: 1 decade ago Dec 11, 2014, 6:51 p.m. EST
In case someone wants to simulate a sheet inductance in a transient simulation, this is how:
On the boundary you need to be inductive, assign a "Boundary ODEs and DAEs (bode)" with
Dependent variable quantity: Surface current density (let's call this jsurf)
Source term quantity: Electric field
In the Distributed ODE section use:
Source Term: temw.Ex (or the appropriate electric field)
Damping or Mass Coefficient: The value of sheet inductance that is needed.
Mass Coefficient: 0
Initial values:
jsurf: 0
δjsurf/δt:0
Then go in the Electromagnetic Waves, Transient (temw) and add a surface current. The appropriate current density will be the jsurf we defined above.
In case someone wants to simulate a sheet inductance in a transient simulation, this is how: On the boundary you need to be inductive, assign a "Boundary ODEs and DAEs (bode)" with Dependent variable quantity: Surface current density (let's call this jsurf) Source term quantity: Electric field In the Distributed ODE section use: Source Term: temw.Ex (or the appropriate electric field) Damping or Mass Coefficient: The value of sheet inductance that is needed. Mass Coefficient: 0 Initial values: jsurf: 0 δjsurf/δt:0 Then go in the Electromagnetic Waves, Transient (temw) and add a surface current. The appropriate current density will be the jsurf we defined above.
