extrude/rotate different domains of a workplane from JAVA
Posted Oct 29, 2014, 10:22 a.m. EDT Version 4.4 0 Replies
I would like to extrude/rotate different domains of a workplane from JAVA, in a controlled way - i.e. avoid the explicit domain numbers because they might change if I make modifs in the geometry upstream.
How can this be done? I can create selections in the workplane geometry (either using a cumulative selection, or using a ball-selection for example based on coordiantes), but these selections are not selectable from the Extrude/Rotate nodes.
Thank you
Daniel
Hello
