Extracting Eigenvalues and Eigenvector using Eigenfrequency study
I was successfully able to extract the first N (~ 50) eigenvalues, using Eigenfrequency study and Solid Mechanics physics setup. I use the export option to write out the frequencies and eigenvalues (lambda).
However, now I also need the corresponding Eigenvectors. I am not able to do the same, since the exporter does not show Eigenvectors in the export list.
Pls let me know how I can export the first N eigenvalue and eigenvectors pairs. Is there is a simpler way to do this using Matlab LiveLink?
Gaurav
2 Replies Last Post Dec 3, 2014, 8:31 a.m. EST
Posted: 1 decade ago Dec 2, 2014, 10:26 p.m. EST
Could someone pls answer. I have seen posts (e.g. www.comsol.com/community/forums/general/thread/31634/) where people talk about having Eigenvectors data access, but am not sure how they actually extract it from COMSOL.
Gaurav
Could someone pls answer. I have seen posts (e.g. http://www.comsol.com/community/forums/general/thread/31634/) where people talk about having Eigenvectors data access, but am not sure how they actually extract it from COMSOL. Thanks, Gaurav
Posted: 1 decade ago Dec 3, 2014, 8:31 a.m. EST
You should be able to select displacements in the Expressions section of Results->Export->Data. If you do not find them in the list, you can always write u, v and w explicitly in the list of expressions.
Which physics interface (element type) are you using? If it is 'subdimensional' (like a shell which lives on surfaces in 3D) you may have to do a manual selection for 'Geometry Level' in Results->Export->Data.
Henrik
Hi, You should be able to select displacements in the Expressions section of Results->Export->Data. If you do not find them in the list, you can always write u, v and w explicitly in the list of expressions. Which physics interface (element type) are you using? If it is 'subdimensional' (like a shell which lives on surfaces in 3D) you may have to do a manual selection for 'Geometry Level' in Results->Export->Data. Regards, Henrik
