How to use a combination of results (from two different solutions) in further study step?
Hi everybody,
As I written in the subject; I'm trying to find a way to use a combination of two different results in further study step
(Hopefully there is another way than exporting and then interpolation function :) )
Thank you,
Can
(I have 4.4 btw)
1 Reply Last Post Dec 9, 2014, 7:38 a.m. EST
Posted: 1 decade ago Dec 9, 2014, 7:38 a.m. EST
Hi everybody,
Thank you,
Can
(I have 4.4 btw)
Hi there
To be more open;
I have a force distribution as a result of 1st study step, which is stored in Solution 1
Then I have another force distribution from 2nd study step (which is stored as Solution 2)
I want to combine and apply the resultant force distribution in a further study step (3rd)
The problem I have is how can I combine these 2 different force distributions to be used in further study step?
(It is possible to see them by using join and with, but I also need to use what I see, I think it' s possible)
[QUOTE] Hi everybody, As I written in the subject; I'm trying to find a way to use a combination of two different results in further study step (Hopefully there is another way than exporting and then interpolation function :) ) Thank you, Can (I have 4.4 btw) [/QUOTE] Hi there To be more open; I have a force distribution as a result of 1st study step, which is stored in Solution 1 Then I have another force distribution from 2nd study step (which is stored as Solution 2) I want to combine and apply the resultant force distribution in a further study step (3rd) The problem I have is how can I combine these 2 different force distributions to be used in further study step? (It is possible to see them by using join and with, but I also need to use what I see, I think it' s possible)
