Regarding coupled two phase level set and heat trasfer in fluids module
Posted Jan 27, 2015, 1:43 a.m. EST Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 5.0 1 Reply
                                                    I am trying to simulate a single hot air bubble in stagnant liquid, say , water. I tried to use two phase level set along with heat transfer in fluids module. For the heat transfer in fluids section i used two initial values, for water, say T= 300 K and for air 800 K . In the fluid section in heat transfer i used the density of the liquid/gas as tpf.rho. there is no provision for selected the bubble inside this module. I results which got to me showed that the bubble is moving up, it is totally fine but with heat transfer the temperature profile look like it is treating the area of the bubble as a solid with initial temperature 800 K . Actually the results should look like the temperature plot on surface should move along the bubble.Please do the needy and thank you in advance....
                    1 Reply Last Post Feb 6, 2015, 8:32 a.m. EST
