Time dependant temperature at the boundary
Rogelio Hernandez Aguirre
I am new in COMSOL, so probably this question will be really naive for you, but I need to ask. I want to apply in one of the faces of my model a temperature that is changing with the time , what I have is a table of 20 set of datas
Temperature Time
20 0
32 300
50 500
55 642
And so on. However, I don't know how to introduce my data to change the boundary condition of the model according to my data, I am trying to use a Time dependent study but I don't know how.
I used a parametric sweep to change the temperature, but this option doesn't let me change the temperature according to the time.
I hope you can help me. I am sure is a really easy issue.
Rogelio
10 Replies Last Post Feb 16, 2015, 3:56 a.m. EST
Posted: 9 years ago Jan 28, 2015, 1:39 p.m. EST
It is possible by defining a piecewise function under Global --> Definitions --> Functions. Remember to add the unit for the argument and the function. Comsol gives the default name "pw1" for your function. Then, at the boundary condition box write pw1(t). I tried this and it works.
Lasse
Hi It is possible by defining a piecewise function under Global --> Definitions --> Functions. Remember to add the unit for the argument and the function. Comsol gives the default name "pw1" for your function. Then, at the boundary condition box write pw1(t). I tried this and it works. Good luck Lasse
Posted: 9 years ago Jan 28, 2015, 7:42 p.m. EST
Thanks Lasse,
Works!. Now I am trying to do something different. Over my time dependent solution I want to use parameter sweep to change the value of one part of the geometry and try to know which is the best dimension of this parameter. However, I am getting this mistake when I click compute, after a while this message appears.
Error in sweep. Incompatible numerical evaluation for table.
do you know why is that? The parameter that I am changing is from 4 um to 8 um. pretty easy!
Regards
Rogelio
Thanks Lasse, Works!. Now I am trying to do something different. Over my time dependent solution I want to use parameter sweep to change the value of one part of the geometry and try to know which is the best dimension of this parameter. However, I am getting this mistake when I click compute, after a while this message appears. Error in sweep. Incompatible numerical evaluation for table. do you know why is that? The parameter that I am changing is from 4 um to 8 um. pretty easy! Regards Rogelio
Posted: 9 years ago Jan 29, 2015, 1:22 a.m. EST
Please attach the model file (delete the results to reduce file size). I tried also that and had no problems.
Lasse
Please attach the model file (delete the results to reduce file size). I tried also that and had no problems. Lasse
Posted: 9 years ago Feb 4, 2015, 12:53 p.m. EST
Hi Lasse,
Attached you will find my model, some explanations about what I am doing:
1.- The parameter sweep of the thickness of my parylene layer is being done on the Auxiliary sweep option under Study Extensions tab. I am pretty sure that the error is related to some meshing issue.
2.- I am also including in my model temperature dependence properties, this was done with a interpolation function that is being called in the Materials property section for the corresponding property. However, I am getting a strange warning message : "Unexpected unit of input", although this message is not stopping the simulation I am worry about if this can lead to a wrong result. I am attaching a screenshot
I hope you can help me Lasse
Thanks in advance.
Hi Lasse, Attached you will find my model, some explanations about what I am doing: 1.- The parameter sweep of the thickness of my parylene layer is being done on the Auxiliary sweep option under Study Extensions tab. I am pretty sure that the error is related to some meshing issue. 2.- I am also including in my model temperature dependence properties, this was done with a interpolation function that is being called in the Materials property section for the corresponding property. However, I am getting a strange warning message : "Unexpected unit of input", although this message is not stopping the simulation I am worry about if this can lead to a wrong result. I am attaching a screenshot I hope you can help me Lasse Thanks in advance.
Posted: 9 years ago Feb 4, 2015, 3:00 p.m. EST
You have to mesh the Parylene domains separately with custom parameters. I suggest minimum element size 0.1 um, maximum 1 um, resolution of narrow regions 4. Then ceramic and glass domains with, say, 1 um minimum, and finally the substrate with whatever size.
Your interpolation table int1 gives temperatures in degC, try K if it resolves the input unit problem, I am not sure.
Lasse
You have to mesh the Parylene domains separately with custom parameters. I suggest minimum element size 0.1 um, maximum 1 um, resolution of narrow regions 4. Then ceramic and glass domains with, say, 1 um minimum, and finally the substrate with whatever size. Your interpolation table int1 gives temperatures in degC, try K if it resolves the input unit problem, I am not sure. Good luck Lasse
Posted: 9 years ago Feb 4, 2015, 3:03 p.m. EST
Thanks Lasse,
I will try with the meshing, thanks for your recommendation. Regarding the interpolation table, I already try changing the units and the warning message still there, looks like is not a error because I can run the model without the parametric sweep and get results.
Thanks a lot!
Thanks Lasse, I will try with the meshing, thanks for your recommendation. Regarding the interpolation table, I already try changing the units and the warning message still there, looks like is not a error because I can run the model without the parametric sweep and get results. Thanks a lot!
Posted: 9 years ago Feb 4, 2015, 4:02 p.m. EST
Forget it, it made ca. 20,000,000 elements! Thin layers are very tricky to handle. Perhaps making Parylene as their own domains is not the way of doing it.
Posted: 9 years ago Feb 4, 2015, 4:31 p.m. EST
If with domain is not possible, what else I can do?
Posted: 9 years ago Feb 5, 2015, 1:28 a.m. EST
Use thin film or thin layer boundary condition where you now have Parylene coating. Without going deeply in your problem I cannot tell exactly how.
br
Lasse
Use thin film or thin layer boundary condition where you now have Parylene coating. Without going deeply in your problem I cannot tell exactly how. br Lasse
Posted: 9 years ago Feb 16, 2015, 3:56 a.m. EST
dont use the Auxiliary sweep from the study extension , try the parametric sweep study.
