Feb 10, 2015, 2:38 p.m. EST
This is not very elegant, but will this do? If you don't have version 5.0, this is the procedure:
1. Create a hollow cylinder and cut it with, e.g. blocks to a desired shape.
2. Draw another block across this tubular wall.
3. Partition the last block.
4. Convert this partition to curves.
5. Remove extra edges.
br
Lasse
br
Lasse
Jeff Hiller
COMSOL Employee
Feb 10, 2015, 3:07 p.m. EST
As an alternative to Lasse's approach:
Since it looks like you have a CAD software, you could import the geometry using the COMSOL CAD Import Module, rather than redrawing the geometry using COMSOL's own drawing tools. The CAD Import Module supports a wide range of formats, including Parasolid, step, sat, IGS, as well as the native formats of a number of common CAD programs (See
www.comsol.com/products/specifications/cad/ for more details).
Since it looks like you have a CAD software, you could import the geometry using the COMSOL CAD Import Module, rather than redrawing the geometry using COMSOL's own drawing tools. The CAD Import Module supports a wide range of formats, including Parasolid, step, sat, IGS, as well as the native formats of a number of common CAD programs (See http://www.comsol.com/products/specifications/cad/ for more details).
Feb 11, 2015, 10:57 a.m. EST
br
Lasse
Thank you very much for your help. Actually I have already tried what you mentioned however I have stuck when I was trying to draw mounted concentric cylinders which are mounted on the concave surface. Do you have any idea if I can draw those cylinders too?
[QUOTE]
br
Lasse
[/QUOTE]
Feb 11, 2015, 11:10 a.m. EST
Since it looks like you have a CAD software, you could import the geometry using the COMSOL CAD Import Module, rather than redrawing the geometry using COMSOL's own drawing tools. The CAD Import Module supports a wide range of formats, including Parasolid, step, sat, IGS, as well as the native formats of a number of common CAD programs (See www.comsol.com/products/specifications/cad/ for more details).
Thank you very much for your advise. I have already tried to Import my CAD file as well. However I have got some geometry issues. So my simulation didn't work properly. I think the attachment explains my problem much better.
Do you have any suggestion for this problem?
Thank you.
Osman
[QUOTE]
[/QUOTE]
Thank you.
Osman
