Varying Geometric Dimension
I am a new user to COMSOL and I am currently doing some acoustic modeling on simple geometries (eigenfrequency analysis)...
I was wondering if there is a straight-forward way to vary a single dimension within my model geometry during the solution process so that I may find its unknown optimal value with respect to my desired frequency.
I have currently been creating separate models with increments in the dimension previously described, which has proven to be quite time consuming...
Thanks Much,
-Jon
4 Replies Last Post Jun 17, 2010, 1:31 a.m. EDT
Posted: 1 decade ago Jun 11, 2010, 4:41 p.m. EDT
Hi Jon,
You can define the geometric parameter you want to vary as a global variable and then use the parametric sweep.
Alternatively, you can use Matlab to create a script and just run your simulation through a for loop, which can be more difficult to do, but is possible.
Best Regards
Hi Jon, You can define the geometric parameter you want to vary as a global variable and then use the parametric sweep. Alternatively, you can use Matlab to create a script and just run your simulation through a for loop, which can be more difficult to do, but is possible. Best Regards
Posted: 1 decade ago Jun 16, 2010, 5:06 p.m. EDT
Chris,
How would you construct a geometry with a dimension that didn't have a definate value?
Also, would this cause problems with the mesh, or does COMSOL automatically compensate the mesh for a variable dimension?
-Jon
[QUOTE] You can define the geometric parameter you want to vary as a global variable and then use the parametric sweep. [/QUOTE] Chris, How would you construct a geometry with a dimension that didn't have a definate value? Also, would this cause problems with the mesh, or does COMSOL automatically compensate the mesh for a variable dimension? Regards, -Jon
Posted: 1 decade ago Jun 16, 2010, 5:34 p.m. EDT
I found in the COMSOL User's Guide (3.5a) that geometric parametric sweeps are enabled if you have licences for the CAD Import Module and SolidWorks or Autodesk Inventor.
I'm assuming that it will take the initial geometric value from the imported models and then vary them.
I am wondering if there is any other way this can be done without interfacing with other programs, including MATLAB.
I found in the COMSOL User's Guide (3.5a) that geometric parametric sweeps are enabled if you have licences for the CAD Import Module and SolidWorks or Autodesk Inventor. I'm assuming that it will take the initial geometric value from the imported models and then vary them. I am wondering if there is any other way this can be done without interfacing with other programs, including MATLAB.
Posted: 1 decade ago Jun 17, 2010, 1:31 a.m. EDT
There are basically two ways, the one yu refer to is making SolidWorks (or inventro or the CAD software) to interact with COMSOL, such that COMSOL can change parameters to change the geometry (without chnginf the topology = no new lost boundaries) and you loop around.
This can also be done with MATLAB an you pilot the geometry of COMSOL commands
Another way is to use the mesh deformations and refer to a deformed mesh. There are several examples around, seaarch on the forum, and in the model examples on the COMSOL web site. There is somewhere a goo example of a I beam optimisation. Thi method does not require any CAD interface
Have fun COMSOLING
Hi There are basically two ways, the one yu refer to is making SolidWorks (or inventro or the CAD software) to interact with COMSOL, such that COMSOL can change parameters to change the geometry (without chnginf the topology = no new lost boundaries) and you loop around. This can also be done with MATLAB an you pilot the geometry of COMSOL commands Another way is to use the mesh deformations and refer to a deformed mesh. There are several examples around, seaarch on the forum, and in the model examples on the COMSOL web site. There is somewhere a goo example of a I beam optimisation. Thi method does not require any CAD interface Have fun COMSOLING Ivar
