issues with pre-stressed and initially-deformed problems
Posted Jun 16, 2010, 11:34 p.m. EDT 2 Replies
I am simulating the transient deflection of a simple cantilever beam under some constant load. It works fine.
In the next attempt I want to give an initial deflection before it undergoes the same external load.
But when I assign the initial deflection that has the same order of magnitude, in the following menu, no change to the solution is observed as if no initial condition was applied.
Physics > Subdomain Setting > Init
This has been of course my 2nd unsuccessful attempt in using initial values for a transient problem. In a Fluid-Structure interaction problem, the solid geometry was pre-stressed and I entered it in the Initial Stress-Strain tab.
Again nothing happened.
Does anyone have any idea how the initial values can work?
Thanks.
Thanks.
2 Replies Last Post Jun 17, 2010, 10:36 a.m. EDT
