Range of values....
Hi everyone..... I want to calculate the maximum change in magnetic flux density at different points... on the x and y axis. For instance if this Bz=u*I/(4pi)*integrate((y-yd)/r^3,x,0,1) is my formula so from this i can calculate the maximum change in magnetic flux density on the yd. Now i defined yd as a parameter which is one value what if i want to make it range of values .... ex yd=range(0,1,5). I defined range in the local variables but it is giving me error. What am i suppose to do to obtain range of yd ...
2 Replies Last Post May 5, 2015, 11:26 p.m. EDT
Vivien Van Kerckhoven
Posted: 9 years ago May 5, 2015, 6:45 a.m. EDT
I m not sure to have correctly understood your question, but I think it's simply a "parametric sweep" you have to do ... Check in the user guide
Posted: 9 years ago May 5, 2015, 11:26 p.m. EDT
Thanks Vivien for the reply. I tried with the parametric sweep but it is giving me the error of circular variable dependency.
