A very basic question
Hi all,
I'm just getting to grips with COMSOL (version 5.0) and I've been following through this tutorial to try and get the hang of the modelling environment.
implicit.che.utah.edu/Teaching/6353/Introduction_to_Comsol.pptx
I'm having a little bother working out where I'm going wrong and would appreciate a few pointers to get me going. I've followed the steps through to the point of computing, but when I try to run the model I get an error saying
Unknown function or operator.
- Name: step1
- Feature: Time-Dependent Solver 1 (sol1/t1)
which I've traced back to the point at which I've defined the inlet velocity but beyond that I'm lost. Is this a predefined function for a previous version of comsol or do I need to define it somewhere else.
any help would be much appreciated.
cheers,
Jamie
2 Replies Last Post May 8, 2015, 5:42 a.m. EDT
Posted: 10 years ago May 7, 2015, 8:27 a.m. EDT
Hello James,
"step1" is the name COMSOL gives by default to the first step function the user creates in their model (under Global>Definitions>Functions>step), but from a quick look I took at the slides it does not look to me like the author of the slides ever creates such a step function. It looks like the author of the slides forgot to document that part of the model set up. You may want to contact them.
Alternatively, you can find dozens of up to date tutorials with step by step instructions inside the software under File>Application Libraries at version 5.1. In earlier versions, look for "Model Libraries" instead. The flow over a cylinder model in the slides seems to be borrowed from there, but you will find many more.
Hello James, "step1" is the name COMSOL gives by default to the first step function the user creates in their model (under Global>Definitions>Functions>step), but from a quick look I took at the slides it does not look to me like the author of the slides ever creates such a step function. It looks like the author of the slides forgot to document that part of the model set up. You may want to contact them. Alternatively, you can find dozens of up to date tutorials with step by step instructions inside the software under File>Application Libraries at version 5.1. In earlier versions, look for "Model Libraries" instead. The flow over a cylinder model in the slides seems to be borrowed from there, but you will find many more. Best, Jeff
Posted: 10 years ago May 8, 2015, 5:42 a.m. EDT
Thanks for a quick response Jeff
