How to change axis grid spacing
hello everyone, I would like to know how to change the grid spacing on the axis. By default Comsol draws the lines depending on the model dimension, i would like to fix this spacing. Is it possible?
2 Replies Last Post May 15, 2015, 11:57 a.m. EDT
Posted: 10 years ago May 12, 2015, 8:42 a.m. EDT
In 2D, yes, through Component>Definitions>View>Axis.
In 3D, not current: you can only turn the display of the axes on or off under Component>Definitions>View
In 2D, yes, through Component>Definitions>View>Axis. In 3D, not current: you can only turn the display of the axes on or off under Component>Definitions>View Best, Jeff
Posted: 10 years ago May 15, 2015, 11:57 a.m. EDT
ok, thanks for the answer
