How to change grid in Geometry?
can someone tell me how to change the grid settings in e.g. "Geometry 1"? Searching the Help for "grid" doesn't really help...
Stefan
3 Replies Last Post Jul 19, 2010, 10:35 a.m. EDT
Posted: 1 decade ago Jul 19, 2010, 7:57 a.m. EDT
Stefan
Do you mean "mesh"?
"Grid" term in comsol is used only as grid on the visual plots (the same you see in photoshop) or the drawing mode.
[QUOTE] Hi, can someone tell me how to change the grid settings in e.g. "Geometry 1"? Searching the Help for "grid" doesn't really help... Stefan [/QUOTE] Do you mean "mesh"? "Grid" term in comsol is used only as grid on the visual plots (the same you see in photoshop) or the drawing mode.
Posted: 1 decade ago Jul 19, 2010, 10:09 a.m. EDT
if its the geometrical "grid" you define it side by side with in the axis, its also described a couple of places in the doc, and in the documented model descriptions (at different places over the docs, and in different location in V3.5a and V4)
Hi if its the geometrical "grid" you define it side by side with in the axis, its also described a couple of places in the doc, and in the documented model descriptions (at different places over the docs, and in different location in V3.5a and V4) -- Good luck Ivar
Posted: 1 decade ago Jul 19, 2010, 10:35 a.m. EDT
Hi Ivar,
ok, i found it.
Hi Ivar, [QUOTE] if its the geometrical "grid" you define it side by side with in the axis [/QUOTE] ok, i found it. Thanks
