Calculate overlap between two different models ( so 2 different studies)
Posted May 21, 2015, 9:07 a.m. EDT Interfacing, Studies & Solvers, Structural Mechanics Version 5.1 0 Replies
I am trying to calculate an overlap between two optical modes (2D), while sweeping a parameter in each model.
For example lets imagine you want to calculate the overlap between two different optical fibers, with sweeping diameters.
1. I defined my first model, and my first study.
2. Did the same for the second.
3. I can plot the modes as a function of the sweeping parameters
4. Using 1D plot/Line Graph, I can plotin the same curve my mode profiles for my different parameters, for each fiber( BUT I CAN'T export it as text, only as plot !) -> I can't do it easily with Maltab.
5. Trying the Join properties doesn't allow me for two sweeping parameters, so I can't compute the overlap in Comsol
What can I do. In the example below I only sweep for 10x10, but If I want a clean colorplot, I will need 100x100...
I anyone has a good idea, I would be very happy ;-)
Hello Jean Teissier
