2D vs axial symmetry 2D modeling, Conical Quantum Dot
Posted Aug 1, 2010, 3:07 p.m. EDT 3 Replies
Hi guys,
I asked the Support, Case: 426303, but got too shallow an answer, and my objections went unnoticed.
It seems the Conical Quantum Dot built-in model (3.5a version of COMSOL) must not produce correct results, if I got it right.
The model is based on 2D geometry, not axial symmetry (2D), while the independent variables are r and z as if it is in the "axial symmetry (2D)" geometry. The independent variables r and z are just names, and COMSOL must have treated them as Cartesian x and y.
But suppose in Cartesian coordinates we have an integral $\int F(x,y,z) dx dy dz$. Its analog in cylindrical coordinates is $\int F(r,\phi,z) r dx d\phi dz$. The extra "r" under the integration sign is just a determinant of the Jacobian of the transformation from Cartesian to cylindrical coordinates. So dealing with cylindrical coordinates all integrals must include unit volume "r". For example, in quantum mechanics, orthogonality of real functions F_1 and F_2 means $\int r F_1 F_2 dr d\phi dz =0 with that extra r.
I'm absolutely sure COMSOL uses some internal integrations to solve a problem, in particular as it must use the weak formulation. Thus for "2D" space it must use the unit volume = 1, and for "axial 2D" the unit volume = r. That's why I doubt the correctness of the Quantum Dot model. Once again, the equation and boundary conditions are fine, but all internal integrations COMSOL uses to solve the problem should have included an extra r.
It can be viewed from different side, the Hamiltonian of the quantum mechanical model is Hermitian only if r is a cylindrical coordinate. Try to use the coordinate r as a Cartesian coordinate x, and you'll have problems with Hermiticity, which might lead to complex eigenenergies.
Guys, am I right?
Another question: can we correct the written model just making a change of a volume parameter like dvol = r instead of dvol =1? But it seems that this parameter cannot be varied...
WBR
Ed
Guys, am I right?
WBR
Ed
3 Replies Last Post Aug 2, 2010, 3:43 p.m. EDT
