Fluid-Structure Interaction In a Cylinder
Hi EveryBody;
I recently heard about Fluid-Structure Interaction, so i want a model with this Physical module in a cylinder if it's possible.
i also want to know if there is a difference between the FSI in Comsol 4.2a and 5.0 ?
Thanks in advance
4 Replies Last Post Jun 11, 2015, 4:47 a.m. EDT
Posted: 9 years ago Jun 2, 2015, 11:44 a.m. EDT
An introductory-level FSI model can be found here: www.comsol.com/model/fluid-structure-interaction-361
I hope it helps you get start.
An introductory-level FSI model can be found here: http://www.comsol.com/model/fluid-structure-interaction-361 I hope it helps you get start. Best, Jeff
Posted: 9 years ago Jun 2, 2015, 3:02 p.m. EDT
thanks Jeff,
This is 2D model simulation, i did it i my comsol before i come here, so i want a 3D simulaion of the modul FSI if that's possible.
thank you sincerely
best regards
thanks Jeff, This is 2D model simulation, i did it i my comsol before i come here, so i want a 3D simulaion of the modul FSI if that's possible. thank you sincerely best regards
Posted: 9 years ago Jun 2, 2015, 3:13 p.m. EDT
The approach illustrated in 2D by that tutorial applies in 3 dimensions as well.
If you face a specific challenge and have an eligible license, please contact COMSOL's support team with your question: support@comsol.com.
The approach illustrated in 2D by that tutorial applies in 3 dimensions as well. If you face a specific challenge and have an eligible license, please contact COMSOL's support team with your question: support@comsol.com. Best regards, Jeff
Posted: 9 years ago Jun 11, 2015, 4:47 a.m. EDT
hello,
i tried from this exemple to simulat this exemple but it doesn't work, so my question is the FSI study the fluid structur interaction of two objects or it can be used with multipl kind of structurs
best regards
SEKHANE Djalal
hello, i tried from this exemple to simulat this exemple but it doesn't work, so my question is the FSI study the fluid structur interaction of two objects or it can be used with multipl kind of structurs best regards SEKHANE Djalal
