heat transfer from water to aluminum
I am having a similar problem. I have a very simple set up with aluminum and water, the water is flowing and is hotter than the Al, so heat should be transferred to the Al through the boundary. However, no heat is passing through. I have tried making a contact pair between the two surfaces, however there is only one edge that can be selected (the Al and water interface falls on the same line). I then use heat continuity under the heat transfer mode. Can anyone help me so that I can get heat flowing to the Al??
Thank you!!
0 Replies Last Post Aug 6, 2010, 1:53 p.m. EDT
Hello Robynne Murray
