Select boundaries inside geometry
Hi all,
I use COMSOL 5. My geometry is a cube and inside of the cube there is a small sphere. To perform my model, I need to select the boundaries of the sphere. The problem is that I cannot select the boundaries crossing the cube...I can select only the boundaries of the cube...
Have you a method to select the boundaries of the sphere crossing the cube ?
Thank you for your help.
Kevin Bartoloni (PhD)
1 Reply Last Post Jun 15, 2015, 11:03 a.m. EDT
Posted: 9 years ago Jun 15, 2015, 11:03 a.m. EDT
Since version 4.4, by default you use the scrolling wheel of the mouse (or equivalent trackpad techniques) to select internal boundaries. You can return to the pre-4.4 selection method via File > Preferences > Graphics Window Selections, if you prefer it.
Since version 4.4, by default you use the scrolling wheel of the mouse (or equivalent trackpad techniques) to select internal boundaries. You can return to the pre-4.4 selection method via File > Preferences > Graphics Window Selections, if you prefer it. Jeff
