Hello Varsha Reddy
8 years ago
Aug 4, 2017, 2:05 a.m. EDT
have you got any solution for this
I am having the same error
if you can help please
thanks in advance
hsshah
thanks in advance
hsshah
8 years ago
Aug 4, 2017, 6:31 a.m. EDT
I am having the same error.plz answer
Walter Frei
COMSOL Employee
8 years ago
Aug 4, 2017, 9:50 a.m. EDT
This error message does indeed appear to be an unusual. To address this we would need to see the file in question.
There is, however, one apparent issue in your description. You have a geometry of 200 x 3 x 0.00342 um. The aspect ratio here is almost five orders of magnitude and whenever you have such extreme aspect ratios you should really look to making some kind of simplification or approximations. Either replace the domain condition with a boundary condition, or consider if you can reduce the problem to a 2D model. This is generally true, regardless of the physics that you're working with.
Best Regards,
Best Regards,
