Phase change material inside a Pipe flow
Hi all,
I need to simulate a phase change material inside a pipe flow (liquid -> gas). So, the transformation is isothermal. I would like simulate the cooling of a concrete slab with a heat exchange pipe. The gas in outlet is slightly superheated, so maybe the solution would be to add a phase change material into the Non-Isothermal Pipe Flow module? What kind of physics would you recommend me to use?
Thank you in advance
Yann
1 Reply Last Post Jul 27, 2015, 7:21 a.m. EDT
Posted: 10 years ago Jul 27, 2015, 7:21 a.m. EDT
Anyone can help me? I'm open to all suggestions ?
Enclosed the geometry.
Yann BALEM
Anyone can help me? I'm open to all suggestions ? Enclosed the geometry. Thank you in advance Yann BALEM
