Magnus Olsson
COMSOL Employee
10 years ago
Jul 30, 2015, 5:48 a.m. EDT
Hi Alexander,
The MEF physics requires gauge fixing when using a direct solver so I guess you used that? When using the default iterative solver, it is generally better not to use gauge fixing. Setting up iterative solvers manually requires a lot of expertise so if it did not work with the default iterative solver or if you got an unphysical solution I strongly recommend that you contact support. Or if you post the model here, I can have a look at it.
Magnus
Hi Alexander,
Magnus
10 years ago
Aug 3, 2015, 4:25 a.m. EDT
Hi Magnus,
first of all, thank you for answering my question.
We both already met on the COMSOL conference 2011 in Milan. We both took a look at my model of a 2d asynchronous motor model (coupled to a stator and rotor circuit) because the solving time was so huge. Maybe you remember ; )
On topic:
Yes, I use gauge fixing whenever I need the MEF physics interface.
I didn't know it should be restricted to direct solvers.
So, I tried to solve the model without gauge fixing with an iterative solver. Unfortunately the results are still not satisfying, but I have to take a closer look at this and do some tests with different solver settings etc.
Indeed, I already simulated and optimized a small transversal flux motor (3D, magnets as flux source) succesfully with the default solver settings (.mf physic interface, iterative solver).
The problem of my current model might be that I'm using a rather theoretical approach (Surface Currents as flux source) and that the default solver settings might be for more practical models...?
This is a very nice offer. Unfortunately this model is a part of my doctorate thesis and I'm not sure about sharing it before my thesis is published. I could think of sharing a simplified version.
Greetings
Hi Alexander,
Magnus
Hi Magnus,
On topic:
[QUOTE]
[/QUOTE]
[QUOTE]
[/QUOTE]
[QUOTE]
[/QUOTE]
[QUOTE]
[/QUOTE]
Greetings
[QUOTE]
Hi Alexander,
Magnus
[/QUOTE]
