10 years ago
Aug 3, 2015, 2:39 p.m. EDT
you are right wen you select a frequency domain and give i.e. only one frequency such as 200[kHz] then you are studying/solving your model for one sinusoidal boundary flux frequency (a current in your case) of amplitude I0 or whatever scalar value you have chosen (check the doc and the theory on frequency domain solver).
The impedance is simply the ratio U[V]/(I[A]), note it will probably be complex ! and it will not work like that if you have I=0 for any reason.
You have several "coil" boundaries, you can define a domain i.e. of copper with a given section and call it a explicitly "single loop coil" of a conductor, but it's far better to use the built-in BC "single coil" or "multiple coil" as these have built-in lumped parameters to directly calculate impedance etc. check the ACDC doc it's al in there. For the multi-turn coil you have additional sub-nodes to even define how the different coils are winded, by layer or columns or ...
10 years ago
Aug 11, 2015, 1:14 p.m. EDT
That was very useful, Ivar, thanks a lot. However, I still got a problem with the coil winding, I want to build a helmholtz coil with 15 turns and 3 layers, I am using the built-in BC 'multi-turn coil' but I can't seem to find the winding options. I have looked into the ACDC module and couldn't find anything about multi-layers coils, I will have a look again but I'd be really glad if you could help me with this.
Kind regards
Kind regards
Nirmal Paudel
COMSOL Employee
10 years ago
Aug 12, 2015, 9:50 a.m. EDT
Unfortunately, there is no "automated" way of doing a multi-layered winding in COMSOL in 3D. You do have to explicitly create a layered structure and assigned a Multi-Turn Coil or Single Turn Coil for each of the layer separately. Hope this helps.
Nirmal Paudel
COMSOL Employee
USA
Nirmal Paudel
COMSOL Employee
USA
10 years ago
Aug 13, 2015, 11:05 a.m. EDT
That does help, thanks a lot, Nirmal!
I've got another question now, I am designing these coils to use in a cryostat, can I simulate that setting the temperature of the multi turn coil domain to the cryostat temperature or should I do something else?
Kind regards,
Thais
Kind regards,
Thais
9 years ago
Sep 15, 2015, 1:56 p.m. EDT
Nirmal Paudel
COMSOL Employee
USA
I have done that, I built a structure with 3 layers and set each as a Multi-Turn Coil and I also set the reference edges for each one of them like in the Helmholtz tutorial, but I am getting a weird profile for the Magnetic flux density in the axis of the coils (
www.dropbox.com/s/rjhjmqnc05fpd43/Multi%20layer%20coils.jpeg?dl=0 ).
I was wondering if I should set the reference edges differently.
I couldn't upload the file because it was too big. I hope you can help me with this, you guy have been really helpful so far, thanks for that!
Coils -
www.dropbox.com/s/na29ad0w86p6vmo/Magnetic%20flux%20density%20vs%20y-axis.jpeg?dl=0
Kind regards,
Thais
[QUOTE]
Nirmal Paudel
COMSOL Employee
USA
[/QUOTE]
I have done that, I built a structure with 3 layers and set each as a Multi-Turn Coil and I also set the reference edges for each one of them like in the Helmholtz tutorial, but I am getting a weird profile for the Magnetic flux density in the axis of the coils ( https://www.dropbox.com/s/rjhjmqnc05fpd43/Multi%20layer%20coils.jpeg?dl=0 ).
Coils - https://www.dropbox.com/s/na29ad0w86p6vmo/Magnetic%20flux%20density%20vs%20y-axis.jpeg?dl=0
Kind regards,
Thais
