give a thickness to a geometry
hi everybody
I made the geometry in CATIA and then imported it to comsol.I want to know if there is a way Ito give a thickness to the geometry(that is 3D,curved tube like)..
any help?
thanx
maral
2 Replies Last Post Feb 28, 2017, 4:21 p.m. EST
Posted: 1 decade ago Aug 25, 2010, 9:39 a.m. EDT
If you have imported a 2D geometry into COMSOL, you can embed, extrude, or revolve it into 3D
this is still slightly version dependent in V4, probably fully impelemneted again in next version (hope so ;)
Hi If you have imported a 2D geometry into COMSOL, you can embed, extrude, or revolve it into 3D this is still slightly version dependent in V4, probably fully impelemneted again in next version (hope so ;) -- Good luck Ivar
Posted: 7 years ago Feb 28, 2017, 4:21 p.m. EST
Hello Maral,
The Design Module includes the "Thicken" functionality that turns a surface into a solid object by giving the surface a thickness: see www.comsol.com/design-module for some screenshots.
This functionality is much more general than an extrusion, which only operates on planar surfaces.
Hello Maral, The Design Module includes the "Thicken" functionality that turns a surface into a solid object by giving the surface a thickness: see https://www.comsol.com/design-module for some screenshots. This functionality is much more general than an extrusion, which only operates on planar surfaces. Best regards, Jeff
