Error with mesh change
I made a simple eigenfrequency study with a beam using a Free Tetrahedral mesh and it worked fine.
But, when I change the mesh type to Mapped and define the size of elements to 5mm, I received an error saying that my Mass Matrix is zero.
Why? I'm attaching my file.
Thanks a lot.
1 Reply Last Post Apr 14, 2013, 5:17 p.m. EDT
Hello Ricardo Amigo
Posted: 1 decade ago Apr 14, 2013, 5:17 p.m. EDT
Hello Ricardo
This problem arises when you have a model with sharp edges. Try filing your edges with reasonable fillet radii. (= Draw a rectangle with filed edges; extrude it to make a block.)
Then apply a mapped mesh to one end face of your block and sweep that mesh along the block.
Problem will be resolved.
Have fun!
Hello Ricardo This problem arises when you have a model with sharp edges. Try filing your edges with reasonable fillet radii. (= Draw a rectangle with filed edges; extrude it to make a block.) Then apply a mapped mesh to one end face of your block and sweep that mesh along the block. Problem will be resolved. Have fun!
