Compressing Walls and Incompressible Water
Payam Haftbaradaran Esfahani
Dear All,
Could you please kindly help me to solve the singularity problem, occurs in the attached model.
This model concerns about a 2D projection of a water container. There are 2 walls, compressing the enclosed water. So, due to the compression pressure, water bulges out of 2 upper and lower open boundaries. I ignored weight force.
So, the 2 left and right compressing walls approach each other by a constant defined speed, causing water to go through 2 open boundaries.
It is a very simple model, but there is singularity, which I couldn't solve it.
I am looking forward for your invaluable advises,
Thanks in advance,
Payam
0 Replies Last Post Oct 1, 2015, 10:42 a.m. EDT
Hello Payam Haftbaradaran Esfahani
