Walter Frei
COMSOL Employee
10 years ago
Oct 6, 2015, 9:23 a.m. EDT
You may want to look at this material, it may point you towards an alternative approach to what you are attempting:
http://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
http://www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling/
http://www.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
10 years ago
Oct 6, 2015, 9:45 a.m. EDT
Alright thanks :)
Alright thanks :)
10 years ago
Oct 7, 2015, 12:49 a.m. EDT
If I want to apply a specific ODE in the region with temperature < 272K, like du/dt = F, but in other region where T>272, I wish to implement another ODE, du/dt=0. This means that depending on the temperature in that particular region, the ODE will switch. Can this be done in comsol?
Gunnar Andersson
COMSOL Employee
10 years ago
Oct 7, 2015, 4:50 a.m. EDT
Use the following expression in the Source Term in the Distributed ODE node: ut-if(T<272,F,0)
