Sep 7, 2010, 10:58 a.m. EDT
An eigenfreuqnecy analyis is a linear analysis developped around an initial starting point (normally stress free).
To get your case with a preload, you need to tell COMSOL to do a static load case, and THEN to linearise the eigenfrequency around the previously calculated initial values. This is solver setting "tweaking". Take the buclking example to study the link stationary analysis + eigemode one (the buckling is a modified eigenmode analysis)
By the way in 3.5 I believe you need to use Matlab, in V4 it can be done internally in teh GUI
Sep 20, 2010, 2:47 p.m. EDT
Ivar,
I am solving an acoustic-structure interaction problem. The analysis type was set as "Frequency response" for solid domains and "Time-harmonic" for the acoustic domain. In this case, if I set a constant value as the initial stress for a solid domain, it is static or dynamic (automatically treat as time-harmonic by COMSOL)? Could you please tell me how to set a static initail stress in a frequency response analysis?
Thanks in advance!
Hongxue
Ivar,
Thanks in advance!
Hongxue
Sep 21, 2010, 1:05 a.m. EDT
the way I have understood initial streess issues are that you must first run a static load case to build up the stress i.e. with external forces, then you save this solution and use it as a starting linearisation point for your frequency domain anlysis (which is by definition/design linear and ignores external forces), then you might couple further.
Now I do not have th accoustic module so I cannot check that part.
I know that the initial stress before eigenfrequency can only be done via matlab in V3.5, but is possible fulli within the GUI in V4 (see as example a buckling example case)
Jul 26, 2011, 11:46 a.m. EDT
Hi Ivar,
I can solve the problem using the example in the documentation of COMSOL "Rotating blade" but the same problem in harmonic analysis. In harmonic analysis the resonance frequency do not change, ie without taking into account the initial stress values.
Thank you
Hi Ivar,
Thank you
