9 years ago
Oct 19, 2015, 2:10 a.m. EDT
I think your computer system uses hyperthreading. COMSOL doesn't support it.
see the link below:
www.comsol.com/support/knowledgebase/1096/
see the link below:
http://www.comsol.com/support/knowledgebase/1096/
9 years ago
Oct 19, 2015, 4:17 a.m. EDT
Usually comsol consider to use half of the cores of your system.
So, if you are going to: Preferences>Multicore and cluster computing>Number of processors
then you can change that section and choose all the cores that you have in your computer.
Hope it helps.
Sepideh
Hope it helps.
Sepideh
9 years ago
Jan 13, 2016, 3:51 p.m. EST
Hi everyone,
I've a similar problem.
I've already read other post, but without solution.
A simply CFD problem (500kelements) runs two times faster on a DELL Alienware for gaming (2013) than on a huge workstation with 32 XEON cores, 256Gb of RAM and SSD (2016, just installed).
When I checked the WS performance, the CPU is used only at 5%.
And I wasn't able to speed up the program.
How to do?
Hi everyone,
How to do?
Jeff Hiller
COMSOL Employee
9 years ago
Jan 13, 2016, 7:49 p.m. EST
Hello Michele,
It is a misconception to think that all problems will solve faster on a more expensive computer. As a starting point, this blog post should be of interest in explaining why a small problem (especially a transient one) can run slower when parallelized:
www.comsol.com/blogs/understanding-parallel-computing/
Hello Michele,
It is a misconception to think that all problems will solve faster on a more expensive computer. As a starting point, this blog post should be of interest in explaining why a small problem (especially a transient one) can run slower when parallelized: http://www.comsol.com/blogs/understanding-parallel-computing/
9 years ago
Jan 14, 2016, 3:04 a.m. EST
Thanks Jeff.
I understand the problem about parallelization, but I deem that the new WS should be runnig faster than the gaming PC.
The old gaming computer is an Alienware DELL (2013).
The new WS is a DELL T7910 (2015).
Here the main performance:
old: 1 CPU i73930k, 6 Cores @ 3.2 GHz - 16GB Ram DDR3
new: 2 CPU Xeon E5 2698 v3, 16 cores @2.3 GHz - 256 GB Ram DDR4
Of course, the bandwith of the memory bus is complitely different between the two computers.
Before removing the license on the old one, I have seen that all 6 cores were used around 80-100% on the old one, whereas only one or two on the new one.
Why that difference?
Thanks Jeff.
