Hello Giuseppe Parisi
May 23, 2011, 5:38 a.m. EDT
I have the same problem, Have you succeeded in modelling it in Comsol V 4.1 ? could you share your experience if you made it?
Regards
Honghui
Regards
Honghui
May 23, 2011, 7:50 a.m. EDT
you can't implement the identity pair condition analog to version 3.5 for version >3.5.
The only way to overcome the problem of absorbing boundary condition is to implement the scattering formalism with a background field as imput.The attached file is an exemple (which was sent to me from comsol support) of implementation for nano grating periodic structure on a substrate.
I hope this can help you.
Parisi.
Parisi.
May 23, 2011, 8:34 a.m. EDT
Thank you very much.
I looked into the the model you sent me, I found that it cannot sweep the frequency, how do you sweep the frequency? did you use script?
Regards
Honghui
Regards
Honghui
May 23, 2011, 9:21 a.m. EDT
you can add a aprametric sweep like in the modified attached file or you can add a parametric under job configuration.
Consider that if you have not a substrate or a complicated initial field, you can operate with an analitical background field as imput field (for exemple a plane wave) in the 'Electric field components solved for ' under electromagnetic waves panel and use it for the scattered field.
regards
p.
regards
p.
May 23, 2011, 11:00 a.m. EDT
Thanks a lot
It is strange, I followed your note, added a parameter sweep sub-node to the study node, and added parameter list under the global definitions. but It did not work for me , the results is always the one for 5e14Hz. Could you please take a look my modified mph file in attachment?
Regards
Honghui
Thanks a lot
Regards
Honghui
May 23, 2011, 11:41 a.m. EDT
hi,
You have not need to add a parametric to job configuration if you have just added a parametric sweep (you can implement only one of them not both).The model i sent you was just modified and complete, you don't have to add anything else.
regards,
g.
hi,
regards,
g.
May 1, 2012, 7:08 p.m. EDT
Hi, Giuseppe,
I also faced the same problem.
I am just wondering why does the mode need two EMWs (full field and scattering filed)?
Do it solve the absorb BC?
And how can we get the transmission and reflection?
Expecting to get your help!
Million thanks!
Hi, Giuseppe,
Million thanks!
May 1, 2012, 8:54 p.m. EDT
"Full field" is used to calculate background field which is required for "scattered field" calculations.
Yes.
You compute the scattered field. Reflectivity is square of the field normalized by incident field. Check the guide on how S-parameters are calculated.
[QUOTE]
[/QUOTE]
Yes.
May 2, 2012, 3:34 p.m. EDT
Hi Alexander
Thanks!
Based on the discussion, I rebuild the model (plasmonic grating) utilizing two EMWs i.e. full- and scattering-field,
However, I found a serious problem.
Actually the model of grating_on_substrate.mph also suffers the same problem.
As we know, there are two solutions (full-field and scattering-field)
The field distributions of the full field- and scattering-field are fine, when the refractive index of the substrate (i.e. n_sub=2) is different from that of the air.
But when I change the substrate as the air, then, the field distribution of the full-field is so disorderly. The field distribution of the scattering-field keeps well.
I really do not know the reason.
Regards!
Hi Alexander
Thanks!
Regards!
May 2, 2012, 6:20 p.m. EDT
Anyone give me some help, thanks
