diffusive_double_layer application not working
Thales Oselin de Lima Machado
Application ID: 21981 seems not be working properly when I tried to simulate on COMSOL 5.0.
I just downloaded it from the application library and tried to follow strictly.Not working!
Undefined variable.
- Variable: cX
- Geometry: geom1
- Domain: 1
Failed to evaluate variable.
- Variable: rho_space
- Defined as: (((cX*zX)+(cA*zA))*F_const)
- Variable: comp1.es.scd1.rhoq
- Defined as: rho_space
- Expression: d((-comp1.es.scd1.rhoq*test(comp1.phi)*comp1.es.d)*(dvol),{test@19})
- Feature: Stationary Solver 1 (sol1/s1)
Is it any error caused because I'm not using 5.2 or was simply my fault in not being that careful in the steps?
Thanks in advance.
Have a lovely day!
Best Regards
Thales Machado
2 Replies Last Post Apr 12, 2016, 7:48 a.m. EDT
Posted: 9 years ago Dec 18, 2015, 4:02 a.m. EST
HI
I found two errors. After fixing them the model works.
1. Variable rho_space must be defined under Component, otherwise Comsol does not understand the variables cA or cX.
2. Under transport of Diluted Species the Electric potential variable must not be User defined but Electric potential (es), i.e. takern from the Electrostatics node.
BR
Lasse
HI I found two errors. After fixing them the model works. 1. Variable rho_space must be defined under Component, otherwise Comsol does not understand the variables cA or cX. 2. Under transport of Diluted Species the Electric potential variable must not be User defined but Electric potential (es), i.e. takern from the Electrostatics node. BR Lasse
Posted: 9 years ago Apr 12, 2016, 7:48 a.m. EDT
Thank you!
Best Regards,
Thales Machado
Thank you! Best Regards, Thales Machado
