2D time dependent heat transfer
I'm a new user and it's my first time trying to simulate a time dependent situation. I have a 2D square that is being heated from the bottom side (boundary heat source) and want to see how the heat proceeds in the sample.
Using the time dependent mode, all I get as a time range is a 0 to 1 range that is divided in 0.1 sections. But what I need to do is to define how long I want the heat to be applied, and be able to see the results at each given time.
Could you please help me with this?
Thank you
1 Reply Last Post Oct 5, 2010, 2:14 a.m. EDT
Posted: 1 decade ago Oct 5, 2010, 2:14 a.m. EDT
1) instead of having a series 1 0.1 0.2 .. 1 you can use any duration
2) if you have time source Q you can define it as a time dependent function, like a two seconds duration Q(t)= 100[W/m^2]*(t<2)
the bolean (t<2) wil go to =0 when t (time) >= 2 [s]
Hi 1) instead of having a series 1 0.1 0.2 .. 1 you can use any duration 2) if you have time source Q you can define it as a time dependent function, like a two seconds duration Q(t)= 100[W/m^2]*(t
