Relative tolerance vs Relative Error
Hi all,
having read many relevant threads and also searched in the comsol manual , i still dont understand the difference (if there is indeed some) between relative error and relative tolerance.
for example:
1)in this thread (also in manual)
www.comsol.com/community/forums/general/thread/13157
''The Relative tolerance value is the relative error tolerance that the ODE solver uses.''
''Use the Relative tolerance edit field to enter a positive number. This number controls how accurately the nonlinear system of equations is solved in each time step. In general, the desired relative error in the solution should be entered here.''
2)in comsol manual
''The software stops the iterations when the relative tolerance exceeds the relative error computed as the weighted Euclidean norm''
suggesting a difference
i need some clarification
V4.4
Thanks in advance
2 Replies Last Post Mar 28, 2016, 4:32 a.m. EDT
Posted: 8 years ago Mar 24, 2016, 10:30 a.m. EDT
Djones-
The simple answer is that that relative tolerance and the relative error are two sides of an inequality expression known as the convergence criterion.
Relative error is the calculated error in the solution attempt.
Relative tolerance is the maximum amount of error that you as the user are willing to allow in your solution.
Iterative processes within the solver sequence will continue to iterate on the solution attempt until the calculated relative error approximation drops below the pre-specified relative tolerance.
Josh Thomas
AltaSim Technologies
Djones- The simple answer is that that relative tolerance and the relative error are two sides of an inequality expression known as the convergence criterion. Relative error is the calculated error in the solution attempt. Relative tolerance is the maximum amount of error that you as the user are willing to allow in your solution. Iterative processes within the solver sequence will continue to iterate on the solution attempt until the calculated relative error approximation drops below the pre-specified relative tolerance. -- Best regards, Josh Thomas AltaSim Technologies
Posted: 8 years ago Mar 28, 2016, 4:32 a.m. EDT
Thank you Josh
Thank you Josh
