Schrodinger equation in COMSOL
I want to set up a model that solves the Schrodinger equation in a particular hexagonal geometry, but I have very limited experience with COMSOL so I am hoping that you can advise me on how to achieve this in the best way.
The Schrodinger equation is an eigenvalue equation so I used the eigenvalue template and set the appropriate coefficients to their value in the equation. Is this also how you would approach the problem?
Either way I am faced with the problem that I want the coefficient u in the generic expression to be a piecewise function that takes on three different values in my geometry. My script is attached and it contains two hexagons and a third polygon which is on two of the facets. I want to define a function that I can use in the coefficient form PDE, which takes on separate values in the smaller hexagon, larger hexagon and on the third polygon.
Could anyone show how to do this?
0 Replies Last Post Apr 11, 2016, 7:33 a.m. EDT
Hello William Heinesen
