Can't export deformed geometry using electromechanics
Posted Aug 29, 2016, 6:11 p.m. EDT MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Geometry, Mesh Version 5.0 0 Replies
I’m simulating the electrostatic force in 2D parallel plate capacitor, and there would be some expected deformation of the two electrodes.The four edges of the plates are fixed constraint. I included moving mesh and geometric nonlinearity in my model, the Moving Mesh is at the top of the physics list. However the deformed geometry I exported from the deformed configuration is the original geometry, not the deformed one. It seems there are some similar problems after 4.3, I would appreciate it if anyone could offer help. By the way in prescribed mesh displacement I could only set the inner boundaries between plates and air to be u and v, I couldn’t select the outside boundaries of the plates cause moving mesh could only be applied to the air inside.
Thanks in advance;)
Hello Dongsheng Lv
